-   Project and Build Forum (https://www.buickforum.com/forum/project-build-forum-42/)
-   -   My neverending project. "Special Ed" (https://www.buickforum.com/forum/project-build-forum-42/my-neverending-project-special-ed-5838/)
2k2cse Nov 4, 2011 08:29 PM
Before I get into talking about my car, I'd like to thank the IB staff for creating this section. Thanks a lot guys, its really appreciated :D
Now, on to my car.
http://img843.imageshack.us/img843/2779/dsc03900l.jpg
I got this car in January 2011, to replace my 2000 Ranger that I wrote off in December 2010. Not long after I got the car,
I started picking away, doing a few small things like disabling the DRL's and ALC.
http://img101.imageshack.us/img101/6220/dsc03972h.jpg
A little later on, I started buying some LED bulbs to replace the interior bulbs. I have blue in the footwells, and white in the map and rear lights. I also bought 4300k HID's.
http://img836.imageshack.us/img836/7767/dsc03978g.jpg
http://img10.imageshack.us/img10/1096/dsc03984pz.jpg
http://img41.imageshack.us/img41/4233/dsc03990ng.jpg
After this, I started in on a little more "custom" work by adding a relay to keep the low beams on when I turn the highs on too.
I also put the car bra that was on the car when I bought it, back on. I do a lot of highway driving, so it helps cut down on the rock chips and scratches.
http://img35.imageshack.us/img35/8387/0726011959.jpg
Next, I done a little painting on the interior. I painted the dash and door handle trim with plasti dip, to give it a Regalish look.
http://img14.imageshack.us/img14/8711/0831011610.jpg
A couple months ago, my cat got plugged up, and caused me some trouble. After replacing it, I found a couple places for a photoshoot. lol
http://img59.imageshack.us/img59/3900/dsc04297x.jpg
http://img233.imageshack.us/img233/7168/dsc04294i.jpg
http://img534.imageshack.us/img534/2387/dsc04305qc.jpg
http://img696.imageshack.us/img696/6725/dsc04306rz.jpg
http://img28.imageshack.us/img28/7856/dsc04312ei.jpg
A couple weeks ago, I painted the chrome trim around the outside black. I think it looks much better.
http://img148.imageshack.us/img148/2...2999550535.jpg
http://img40.imageshack.us/img40/516...2999425535.jpg
And, this is my latest project, blue led interior lighting :D
http://img856.imageshack.us/img856/4539/1101011852.jpg
http://img189.imageshack.us/img189/2029/1101011851.jpg
I just have the one strip right now. I'm waiting for more to come in the mail.
This all brings us to today, when I changed my 4300k bulbs for 6000k
http://img85.imageshack.us/img85/1475/downloadqj.jpg
Its hard to tell, but I have my high beams on too for comparison
hanky Nov 5, 2011 05:10 AM
Nice work and nice pix too !
2k2cse Nov 5, 2011 10:35 AM
Thanks man. Its slowly getting to how I want it. Just as long as the car stays running by then. haha.
Merc6 Nov 5, 2011 08:16 PM
Intrested in that ALC and how you got around it. How hard was it to paint the dash and remove the vents? I found a Wodgrain sheet and not sure if I want to tackle that or not for that dash pannel and doors. Like the blue lighing I was debating on doing the same but with white leds. My subaru I used red with white map lights. Was concert sound II standard after a certain year or was that a SE package with the astroroof? Didn't intend to hijack your thread.
*EDIT* just noticed the panoramic dash pic.
2k2cse Nov 5, 2011 11:24 PM
The ALC was really simple. Just add a 4.7k ohm resistor across the wires for the sensor at the BCM.
The dash was fairly easy to come apart, the vents just clip in. It was a little time consuming doing it the first time, trying not to break any of the clips, but after the 4th or 5th time taking it apart, you get used to how it comes apart. haha. Its all clips, except for a screw under the the fuse panel cover on the passenger side. You have to open the glove box, and pull the lower dash piece down. There are a few videos on youtube showing how it comes apart.
Concert sound II was either part of the "Custom" package, or the "SE" package, i'm not sure, and was also available as an option on the base model too, i think.
Let me know if you have any more questions ;)
I also fixed my dead odometer display tonight. I took out the old resistors, and soldered in 4 150 ohm resistors. Less than an hour later, and its as good as new :D
Merc6 Nov 6, 2011 05:33 AM
Yeah I seen the dash video just not the vents. Whenever I do the resistors in the cluster I'm going leds. That hasn't broke, yet.
Merc6 Nov 10, 2011 08:57 PM
I forgot to tell you I got practice with removing the dash trim to get that 200 KM/H cluster out of the wrecked C2K. Hardest part was the shifter in park. Still haven't taken it apart to see how the leds are set up.
2k2cse Nov 10, 2011 09:09 PM
Haha yeah, that must have been difficult. Its enough trouble with the shifter in 1st. I tried putting a blue led 194 bulb in place of one of the bulbs when i was putting everything back together. It turns out, that bulb went a little wacky on me before i put it in, and it wouldn't light up either way. I'm thinking about adding an AUX port to the stereo next weekend, so I might try again with a different bulb. I'm interested in seeing what the green overlay would look like with a blue bulb behind it.. I doubt i'll get into replacing all the small bulbs with LEDs. Who knows. haha
Merc6 Nov 10, 2011 09:32 PM
Didn't check the bulb size that twist out the back. Most books refuse to give me usable info. My major complaint in all of this would be the needles being super dim.
2k2cse Nov 10, 2011 10:09 PM
The twist out ones were 194 or similar size -> t10 LED. I'm doubting my plans of blue will work, but white bulbs could work. Unfortunately, all of my white bulbs are in places that are too difficult to access to test out in there. I'll see if I can take one out of my map light for when I do the radio.
