Sticky Ignition causing Traction Control and Check Engine light.
Old Jun 28, 2024 | 09:57 PM
arnoldsmind's Avatar
Default Sticky Ignition causing Traction Control and Check Engine light.
I re routed the starter switch to the back seat and resolved the TCC and Check Engine light that was popping up. The Error code was P1864 TCC Solenoid. Transmission ran fine. My fix may help someone. I was worked about changing the ignition with the passkey, so I opted for this solution.
Here is the work I did:
https://youtu.be/j83B2DZslnY?si=drXKHgvu2rNNXTus
AAR6
Jun 23, 2019 08:51 PM
razor
Jan 6, 2018 10:17 PM
friskie
Apr 16, 2016 09:56 AM
Showman
Dec 23, 2012 01:42 PM
