PLEASE HELP !!!!!! DIM lights on Odometer / PRND321 Display - 03 Rendezvoux
Hi all,
First timer here... The display containing the Odometer / PRND321 has gone Dim, sometimes is half as Dim, and sometimes when I tap on the cluster or there is a bump on the road it changes the light's intensity. Does anyone have the fix for this? This is what I have done already: Removed cluster Opened up unit - (Replaced stepper motors while I was at it) Searched for a section with multiple resistors (as stated in other posts) Attempted to re-solder (fix) the connection of those resistors Tested the cluster -- Failed (same issue) Re-soldered another set of resistors Tested the cluster -- Failed (same issue) Re-soldered ALL connections for the display (about 15 on bottom and 15 on top -- sorry did not count them) Tested the cluster -- Failed (same issue) I continued to check for solutions for Buick Rendezvoux (or any other GMC, chevy, Cadillac, etc) of a similar build and year but I found nothing applicable (older models have a different problem and therefore a different solution - or maybe the same problem but at a different point on the PCB) ANYONE???? Thank you all !! |
Originally Posted by orale78
(Post 13614)
Hi all,
First timer here... The display containing the Odometer / PRND321 has gone Dim, sometimes is half as Dim, and sometimes when I tap on the cluster or there is a bump on the road it changes the cheap hid headlight kits intensity. Does anyone have the fix for this? This is what I have done already: Removed cluster Opened up unit - (Replaced stepper motors while I was at it) Searched for a section with multiple resistors (as stated in other posts) Attempted to re-solder (fix) the connection of those resistors Tested the cluster -- Failed (same issue) Re-soldered another set of resistors Tested the cluster -- Failed (same issue) Re-soldered ALL connections for the display (about 15 on bottom and 15 on top -- sorry did not count them) Tested the cluster -- Failed (same issue) I continued to check for solutions for Buick Rendezvoux (or any other GMC, chevy, Cadillac, etc) of a similar build and year but I found nothing applicable (older models have a different problem and therefore a different solution - or maybe the same problem but at a different point on the PCB) ANYONE???? Thank you all !! |
| All times are GMT -5. The time now is 11:37 PM. |
