ABS and traction control lights on
Hi there, Im new here.
I have a 2006 Buick Lucerne that runs great. The last 4 times I've driven it, the ABS and traction control lights come on. Only once the battery light came on with it but not since. I noticed the last time I drove it after the lights came on, my cruise control shut off by itself. I first thought I accidentally shut it off but when I put it on again, it shut off again. The car did not go into limp mode and still drives beautifully. Same power, no noise, etc. No wires that I see hanging down but thats just on the ground. I didn't get under the car on a hoist because I don't have this luxury unfortunately. Fuses are all okay. The funny thing is when I put the OBD II reader on it, there were no fault codes. Not sure why? Help anyone. I read somewhere that maybe the ABS codes are on a different scan reader? I know someone, somewhere out there knows. Thanks a lot |
Were you driving under any conditions that allowed the wheels to slip ?
Sometimes a wheel bearing is worn and allows the signal to a wheel speed sensor to become intermittent and this will set a code that you could have checked for no cost from places like Autozone. Can you do that? |
| All times are GMT -5. The time now is 05:05 AM. |
