07 Lucerne CSX power steering
Replaced the motor with a 4.6 from a 2011 Caddy. Swap went fine but now we have no power steering. Took the pump off the caddy motor and put my pump from the 07 Buick motor back on. That one worked fine before. Still no power steering. Fluid is creamy colored which should indicate air in the system. Cycled the rack and pinion back and forth 3/4 turn to 3/4 turn approximately 50 times. Still not power steering. I'm at a loss. Any ideas or thoughts. Thanks in advance.
Jimbo
Jimbo
Original 4.6 '07 motor blew up. Replaced with a '011 caddy 4.6. Left PS pump on because it was 4 years newer. After we got new motor running, we had PS for about 15 min then it quit working. Replaced PS pump with the '07 pump which we knew worked fine before. Again it worked fine for about 15 min then quit. ???? Would doing a PS fluid flush fix it?
Jimbo
Jimbo
Jul 20, 2018 12:11 PM
BuickBag
Aug 30, 2011 11:41 AM
