transmission mount
Old 07-23-2018, 06:56 PM
carnutbill's Avatar
Default transmission mount
How do you change transmission mounts on 2000 Buick LeSabre?
Ebay sells a package of 4 mounts, 2 engine mounts & 2 transmission mounts.
The engine mounts in front of the engine & behind the passenger side wheel were easy to replace, but how do change the 2 transmission mounts?
Old 08-01-2018, 06:17 PM
Usually you remove the driver's side wheel and the inner fender and the mounts are now visable..
Old 08-01-2018, 08:02 PM
carnutbill's Avatar
Thanks for the reply. After I replaced the front engine mount I removed the left front tire & replaced transmission mount. If I were going to replace the front mount & the left & right side mounts again I would replace the side mounts first. I think it would easier to replace the side mounts with a broken front mount. If just the front mount was broken I would only replace the front mount.
Old 08-01-2018, 08:24 PM
carnutbill's Avatar
Default Engine/Transmission mounts
Attached pictures show front & left side mounts. I got the left side mount started & then used a piece of wood & hammer to push it in all the way. I drill the mount with a 1/2" drill bit so the mount would go in easier. I think the side mount would have gone in easier if I had replaced the front mount last.
Attached Thumbnails transmission mount-buick-left-side-trans-mount.png   transmission mount-front-engine-mount.png   transmission mount-mount-removed.png   transmission mount-drill-mount.png   transmission mount-install-mount-.png
Old 08-02-2018, 09:02 AM
Thanks for the info and update.
Old 11-11-2019, 10:33 PM
Frampton1007's Avatar
Default No drilling
I don't believe I would reccomend drilling anything to make it fit easier. That mount stud could "walk" around inside where you drilled wouldn't it?
filthy1
03-03-2013 07:06 AM
greendurango
12-28-2011 11:39 AM
blu3g
05-10-2008 11:04 AM
blu3g
05-10-2008 11:03 AM
stressdoc
07-06-2007 11:49 AM
Quick Reply: transmission mount
