transmission mount
How do you change transmission mounts on 2000 Buick LeSabre?
Ebay sells a package of 4 mounts, 2 engine mounts & 2 transmission mounts. The engine mounts in front of the engine & behind the passenger side wheel were easy to replace, but how do change the 2 transmission mounts? |
Usually you remove the driver's side wheel and the inner fender and the mounts are now visable..
Thanks for the reply. After I replaced the front engine mount I removed the left front tire & replaced transmission mount. If I were going to replace the front mount & the left & right side mounts again I would replace the side mounts first. I think it would easier to replace the side mounts with a broken front mount. If just the front mount was broken I would only replace the front mount.
Engine/Transmission mounts
5 Attachment(s)
Attached pictures show front & left side mounts. I got the left side mount started & then used a piece of wood & hammer to push it in all the way. I drill the mount with a 1/2" drill bit so the mount would go in easier. I think the side mount would have gone in easier if I had replaced the front mount last.
Thanks for the info and update.
No drilling
Originally Posted by carnutbill
(Post 16250)
