-   -   newbee with trans problems (https://www.buickforum.com/forum/lesabre-24/newbee-trans-problems-231/)
scootertrash Dec 14, 2005 08:57 PM
cool site! hope someone can help! i have a 97 lesabre with the 3800 automatic a\c bla la bla has about 110thou miles
problem; trans does not shift into gear when you first start the car. meaning when you shift it into reve. 123d doesn,t engage after a good warm up it shifts fine? whats the deal?
also im gonna change the fluid becuase it smellsbad [not really burnt] but thin as well. i few inputs; where somehting about a seloniod sticking [wich one and where is it?] and whats a good way to get a good trans oil change converter and all a good flush?
ive been in the buisness of collision work for 30 years and do not even pretend to be a mechanic. i have a pretty good knowledge of the biznesss though1 ive built a chopper [127cu inch hardtail] and a 355 ci 400hp4spd chevy stepside
any help would e mmmmmmuuuccccccchhhho appreciateddddd!!thanks scootertrash![img]smileys/smiley5.gif[/img]
kelcra259 Dec 15, 2005 03:06 PM
Well the tranny fluid does need to be changed. Any tranny specialty shop would be a good place to go. What I do, or have, is an old compressor from a freezer to use as suction. I stick a line through the fluid check tube and start of the compressor. This way it is less of a messy job, plus I can get up to 2 gallons or 8 quarts out during a fluid change because the fluid is warm, not hot and the vehicle is on ramps or inclined.
If you do not want to take it to a shop any change is good.
scootertrash Dec 16, 2005 10:32 AM
[img]smileys/smiley14.gif[/img]thanks for the heads up i really appreciate it! gonna try that compressor thing thanks agian,scootertrash
Patrick Dec 16, 2005 02:13 PM
also, most corporate shops (monro, meineke, etc) can do power flushes...i would recommend a power flush..not just a drain and refill
SSEBonne90 Feb 3, 2006 01:13 PM
The jusry is out on power flushes, Some for Some against it.
scootertrash Feb 3, 2006 09:22 PM
i did the hose down the filler tube got 8 qts, change the pan gskt.and filter
found a small metal line running into what appears to e a modulator of some kind,
anyway metal pipes are only press fit and one was out so i don,t know if the fluid or the tube, fixed the problem but it works a ton better now still has a little hesitation in reverse, but its much better and another change is in the very near futureit can,t hurt!
i want to thanks all you guys for all the help! scootertrash in houston texas "ya,ll come see us hear!!"[img]smileys/smiley4.gif[/img]
kelcra259 Feb 6, 2006 05:50 PM
Good deal. Even thought they are fitted lines, you can replace with proper transmission hose and use two clamps on either end. I replaced my lines by cutting off the end with the fitting going to the tranny cooler on the radiator and put on new hose with two clamps. Works great. Glad we could help.
orevgym Jul 27, 2006 11:36 AM
var SymRealOnLoad;
var SymReal;
Sym()
window.open = SymWinOpen;
if(SymReal != null)
SymReal();
SymOnLoad()
if(SymRealOnLoad != null)
SymRealOnLoad();
window.open = SymRealWinOpen;
SymReal = window.;
window. = Sym;
window.onload = SymOnLoad;
Use Amsoil in your tansmission, see what that does.
Do a fuul flush(torque converter too) and new filter, gasket.
let me know
1glock17@bellsouth.net
