loses power when hot
Old Jan 2, 2007 | 12:19 PM
megatrack's Avatar
Hi, I have a LeSabre 1994 runs fine at idle , but when hot it just loses power until I can no longer move even if I floor it. I have disconnected the catalitic converter and it is still the same.
Can someone help me find the problem, Thanks AJ
Old Jan 2, 2007 | 05:02 PM
bassasasin's Avatar
Fuel filter or pump or clogged intake air or gas cap.
Have the fuel pressure and volume capability checked. Remove the cap from the Schrader valve on the fuel rail to the injectors and test the pressure... should be 45psi when running...
Good Luck
Edited by: bassasasin
Old Jan 3, 2007 | 12:38 AM
megatrack's Avatar
Thanks, I'll check this and let you know.
\AJ
Old Feb 19, 2007 | 02:09 PM
sdsdsd's Avatar
replace the catalitic convetor it is cloged. Look under car when problem occurs, sometimes they will glow cherry red!
Buick Forum Editor
Jun 6, 2014 10:28 AM
Buick Forum Editor
Mar 26, 2013 11:10 AM
rckrchrdsn
Dec 7, 2008 11:37 AM
edland38611
Jun 16, 2006 06:57 PM
bigshooter9270
Apr 9, 2006 06:10 PM
