-   -   left turn signal problems (https://www.buickforum.com/forum/lesabre-24/left-turn-signal-problems-3775/)
taranov Feb 7, 2010 11:43 AM
My left turn signal was been flashing a lot faster than usual. Does anyone know why this happens and how to fix it? Is it indicative of a serious problem?
big chuk Mar 6, 2010 07:05 AM
It sounds like you have a bulb burnt out on the left side, or if you recently replaced one it may not be installed corectly. Turn your signal on & inspect the car to see if all of your signals are flashing.
mnewbolds May 24, 2010 07:42 AM
I had the same problem, mine turned out to be the parking light/turn signal socket in the front on the lower driver's side. $23 for the new socket and all is well. But it may just be a bulb. If the system detects a bad connection (blown bulb) it notifies you by flashing at a higher rate of speed.
