The gas guage on my 2000 LeSabre is acting up. It seems to work OK from full down to about1/2 a tank, then it will start moving up to about 3/4 to full and back every few minutes.
Any ideas? Thanks George |
The most likely cause is the fuel level sensor. I've seen them go bad before. The fuel sending unit can be accesed through the trunk but you need to have a special tool to get it out.
Speacial tool is brass Rod and Brass malet. You can't have any sparks!
Any ideas? Thanks George I'm having the same problem. I also notice when thefuel levelgets down to 1/2 full the service engine light comes on and I have a "gas cap loose" message. Fill the tank and both problems go away. Can fuel sending unit be replaced by a shade tree mechanic. What's the need of the brass punch? |
| All times are GMT -5. The time now is 11:43 PM. |
