Flaky cruise control in 1993 Custom
Old May 31, 2008 | 05:37 PM
GatorInAtlanta's Avatar
I have a 1993 LeSabre Custom, and the cruise control has been inoperative for awhile. If I try to enable it (move ON/OFF switch to ON and press SET), it may kick in for few seconds and then quit, but most of the time the cruise light simply flashes once and then stays off when I press the Set button.
At the connectors to the Powertrain Control Module (PCM) I have verified the following:
To check the CC switches on the lever, I checked
12 volt on pin D2 of C3 (the green connector) when the ON/OFF switch set to ON.
12 volt on pin D3 of C3 when SET button pushed (and ON)
12 volt on pin D4 of C3 when Resume pushed.
To check the brake switches, I checked
12 volt on pin D10 of C1 (large black connector) when ON/OFF in ON, that goes away when brake pedal is depressed.
12 volt on pin A5 of C2 (smaller black connector) that goes away when brake pedal depressed.
(Note: All the above voltages were OK. When I checked them, I wiggled, shook, etc the CC lever and brake pedal to try to get a failure but couldn't)
Checked continuity of wiring between PCM connectors and the connector for the cruise control servo, and between the PCM and the Vehicle Speed Sensor (VSS). VSS seems to be working - I unplugged it and got Check Engine Light and no speedometer.
Checked all vacuum hoses. Even set up a test where I applied voltage to operate the vacuum solenoid and vent solenoid in the CC servo. The servo caused the engine to accelerate perfectly, which should indicate that vacuums were there and functional.
I can't think of anything else to test. Maybe the PCM itself is faulty, but I don't know how to tell. Anyone have any ideas of additional things I could try. Thanks.
GatorInAtlanta
Jun 1, 2008 07:38 AM
banjo2k
Mar 5, 2007 12:58 PM
Stephen
Aug 4, 2006 02:59 AM
Marshall
Feb 26, 2006 09:59 PM
Stephen
Aug 29, 2005 05:26 PM
