the engine dies then restarts their was a 18x code. now it dies and dosen't restart for 10 or 20 min. got a knock sensor code. when I scanned it I had 18x 166 whenthe eng. was not turning. when cranked the 18x & 3x signal went crasy a second then started. now it run fine for week or two then it will do it again. thiss started after a broken valve spring was replaced only ing module & one con. were diconnect. |
Sounds like a Crank sensor..
WHat year car? What Mileage? What do you mean the 18x and the 3x.. the signals from the sensor? Must have been on a analyzer.. of some kind. Your post is fractured here.. Bass |
| All times are GMT -5. The time now is 12:45 AM. |
