Brake Problems
Old Mar 16, 2007 | 01:32 PM
Segaman's Avatar
I have a 92 Buick Lesabre, I am having trouble with the brake on this car. I only have brakes on the front drivers side and the rear passangers side. My pedal goes to the floor (very little stopping power). Rear brakes are ALL new I replced every pcs. I tried the master cylinder but fluid comes out both sides (front and back holes).
Any help would be appreciated.
Yes I have bled the brakes multiple times (wasted1 gallon brake fluid).
Thank You.
Old Mar 16, 2007 | 02:09 PM
MrBSS's Avatar
Might still be the master cylinder. Sounds like one side is bad or at least leaking under pressure. Also, a master usually has to be bench bled if air has entered. Another possibility is in the ABS system.
Old Mar 16, 2007 | 07:58 PM
bassasasin's Avatar
Possibly air got in the Master cylinder. </font>
Can you ever pump up your brakes at all?
Are you leaking any fluid?<br style="font-style: italic;">
</span>If you can, does the pedal continue to fade down after it becomes hard?</span>
Proper bleeding can be a nuisance, Here are my notes.
Try my checklist.
</span>
</span>Pumping pedal is slowly but firmly.
DOT 3 brake fluid.
<ul>[*]If there is suspect air in the master cylinder.[/list]Bleed Master Cylinder.
To bleed Master Cylinder
<ul>[*]Never allow the reservoir to empty below half.[*]
Open the front line and fill till fluid drains without air.[*]Reconnect line and close and tighten the line to 24 ft lbs.[*]
Get an assistant to slowly press the pedal while cracking the connection and checking for air.[*]Wait 15 seconds and repeat.[/list]
Apply this process for the rear master fitting.
</span>Bleed the wheels in proper sequence.
</span>
Follow the sequence for the wheels according to body type.
DOT 3 brake fluid.
Never reuse brake fluid.
Bleed sequence depends on BODY Type VIN#
Yours is LeSabre.. Checking it shows sequence.
  1. RRrear
  2. LRear
  3. RFront
  4. LFront
Checking manual.. nothing mentioning ABS in this area.
Edited by: bassasasin
RSXS34
Feb 13, 2026 04:57 PM
smshall
Jul 29, 2015 10:50 AM
vivalabui
Jun 2, 2007 07:40 PM
tegger
Jul 11, 2006 05:34 AM
BigRich
Jan 6, 2006 10:15 PM
