98 buick lesabre ignition issues
Old Jan 11, 2023 | 04:59 PM
Tacoma_blaine's Avatar
Default 98 buick lesabre ignition issues
https://youtu.be/vej4eNhkVAk
I made a video to show what is happening
this is not some stupid ad or anything just a 2 min video showing what is the issue
i think someone tried to break my ignition and steal my car
Now, when I insert key and turn to ON position, I get none of the dash lights as normal
If I apply slight pressure on the key, then I get dash lights
If I crank the key all the way, my car starts but then turns off when i release.
if i crank the key, and start the car and then HOLD the key slightly forward the car runs
I do not think this is a security system issue
I think the problem could be fixed with new ignition switch?
Old Jan 12, 2023 | 01:03 PM
You are most likely correct.
The thing to do is verify power is getting out of the switch itself and that can be easily verified with a simple test light.
The sw assy is usually located under the dash attached to the lower part of the steering column..
Tacoma_blaine
Jan 11, 2023 04:07 PM
rtrollins
Feb 14, 2021 01:56 PM
JRT
Feb 14, 2021 01:35 PM
caninecodependent
Mar 8, 2017 05:23 AM
gt4awd
Apr 21, 2011 03:47 AM
