97 LeSabre cluster problem
Old Feb 15, 2006 | 10:54 PM
daben's Avatar
I have a 97 LeSabre with the ub3 cluster. The fuel reads full all the time, the tach is eratic, the speedometer works when it wants to. I can tap the top of the dash and the tach goes crazy. The cruse works perfect when the speedometer isn't working. Any ideas before I change the cluster?
Old Feb 16, 2006 | 02:52 PM
Erakiel81's Avatar
It's certainly a "cold welding" (not sure if i spell it right in french we call this Soudure froide). If you can try to remake all welding on the cluster. I'm sure it will correct the problem.
I also get a similar trouble on my astro, it was a broken bulb that make a ground contact (hard too beleive but this was really the cause !)
Old Mar 9, 2006 | 12:52 PM
SSEBonne90's Avatar
Youll have to remove the cluster and check and clean all the connectors first.
FoxClover
Aug 30, 2010 10:14 PM
mecanovi
Jun 28, 2010 01:10 AM
pkoksvik
Jun 13, 2007 01:19 PM
budone
Sep 8, 2005 04:50 PM
ray97
Jun 4, 2005 12:56 PM
