95 Buick Lesabre 3.8 V6, missing coolant, can't find leak anywhere?
Just did oil change, noticed trans. cooling lines leaking at the rubber metal compression ends, decided to change them. That is all done but I am still finding the antifreeze overflow low. I add a 1/2 a quart of antifreeze everytime I check the motor oil level. Why am I down on antifreeze? Water pump was changed about a year ago. They needed to change a plastic cracked piece next to the water pump as well. They said they replaced it with a metal one. Not sure what this metal piece is but it was leaking antifreeze. New pump, no leaks I can find but the overflow is low.... Not sure why? Any suggestions? Thanks
Buicks had a problem with the intake plenum leaking anti freeze into the cyls. You cannot see it , but it gets burned off through the exhaust until it gets bad enough. I would suggest you either invest in a cooling system pressure tester or have the cooling system pressure tested at a reliable shop and see if it holds or loses the pressure. Depending on those results will determine your next move.
Originally Posted by hanky
(Post 9127)
| All times are GMT -5. The time now is 03:26 AM. |
