94 lasabre keyless remote program
Old Oct 6, 2005 | 06:44 PM
buik94lesabre's Avatar
does anyone know the programming instructions for resetting a keyless remote for my year car. my car battery went dead while i had the hazard flashes on getting a tire changed and when i got ready to get back in my locked car, i couldn't use my remote to unlock it. had to manually unlock with the key. haven't done that in so long i almost forgot how(LOL). anyhow, i've replaced the battery in the remote and it still doesn't work. if anyone knows how, it would greatly be appreciated.
Old Jul 26, 2006 | 10:58 PM
bassasasin's Avatar
SUre.. it takes shorting certain pins on the computer plug under the steering wheel . listening for a double click of the door locks. Pressing the unlock button on the keyless
Here YA GO.. one of my posts. [img]smileys/smiley2.gif[/img]
To Program a Buick Lesabre 92-94.
Under the steering wheel above the Brake pedal is a 16 pin OBDII code readerplug.. Remove your car keys. Jumper ( paper clip) short pins 4 (ground and 8 (erase program) (8= rear of car right corner) It's all upside down there so be careful.. It looks like top right Looking at it.. there are pins visible in 4 and 5 and 8 showing silver contact points. HOLD the connection.. Paper clip will stay/snap in easy. The doors will lock and unlock twice then press your remote unlock key button. Doors should click. If not.. something else is wrong. If you have two remotes .. have it available and press unlock on the second remote. The Doors should unlock again.. Be sure you press the "UNlock button.. Mine was in the center of the remote.
YOUR DONE[img]smileys/smiley17.gif[/img]
Old Nov 25, 2008 | 09:43 AM
mucha's Avatar
</span>
</span>
Most remotes
can be programmed manually at home without any tools or technical skills. </span>
If you need to
just order the instructions please check our website at </span>
http://www.carandtruckremotes.com/pr...instructions.h tml</span>
If you have any
more questions or have any specific inquiries about programming your vehicle
please contact us at customercare@carandtruckremotes.com
including year, make and model of your vehicle. </span>
You can also
view our FAQ page for answers to common questions. Link below</span>
http://www.carandtruckremotes.com/faq.html</span>
Best Regards</span>
Customer Care </span>
http://www.carandtruckremotes.com</span>
http://www.newkeylessremotes.com</span>
http://www.keylessentrystore.com</span>
Old Nov 25, 2008 | 10:22 AM
coyoteee's Avatar
Originally Posted by mucha
BAN!!!
</span>
</span>
Most remotes
If you need to
If you have any
You can also
Best Regards</span>
ShooterD
Aug 8, 2017 09:15 AM
Thores Stone
Sep 21, 2013 08:47 PM
corelite
Mar 2, 2009 09:15 PM
corelite
Feb 28, 2009 10:22 AM
koobiidoobii
Nov 25, 2008 11:37 AM
