"Studder" Diagnosis
Old Oct 6, 2006 | 03:30 PM
Shon Herron's Avatar
Very repeatable issue. Car is a 99 LeSabre with the 3.8, 72k miles. Great car, might need shocks but otherwise great car. But have a problem that has risen within the past 1k miles or so.
I can be going in 4th and TC locked up; 45-50MPH/less than 1500RPMs, come to a hill/incline to put the car under load and it "shudders", if feels like a VERY Hard TC lockup or lockup and unlock real fast but the RPMS do not change, it will do it all the way up the 'hill' or until I give it more throttle and it comes out of lockup. I can repeat this scenario easily and just about tell when it is going to start shuddering.
The SES light has not come on.
What to do first?
Old Oct 7, 2006 | 03:08 AM
bassasasin's Avatar
I think Ive heard of this.
Two possibilities I can think of.
Does sound like the TCC valve is leaking ... In that case its called a CHUGGLE.
Check out the symptoms on research of CHUGGLE.
I think there are prom changes that help during shifts with but its not a fix just a work around.
If it is it might help to change the transmission fluid.. and maybe a
additive. The valve fattens up a bit with the additive.
Elsewise a trannie workover..
The other possibility (but your throttle mention disuades this) is just
a plug giving it up and misfiring somehow. Under high cylinder
pressure the resistance increases across the spark plug and the spark
finds another route like a wire to ground or inside a coil pack.
Good Luck.. hope this gives you some ideas.
Ansis42
Jun 8, 2013 01:55 PM
