Question about Drip from 06 LaCross
Old Dec 14, 2015 | 02:28 PM
congaman59's Avatar
Default Question about Drip from 06 LaCross
I have an 06 LaCross 3.8L CX. Has about 150,000 miles on it. I noticed water under the car yesterday afternoon. I started the car and knelt down behind the right side wheel and saw water dripping from the frame behind and to the outside of the oil pan. I suppose it must be coming from the cooling system. What would be in that area near the firewall to drip like that? I looked all around the motor and and I didn't see any leaks from any hoses. Is the water pump in that area (on the right side) underneath the rear of the motor?
Edit Post Reply Reply With Quote
Old Jan 17, 2016 | 01:15 PM
rgp's Avatar
rgp
Tell us where you are located. If you posted this in December and it's water and not antifreeze then you must be in a warm climate and you had the air conditioner running. If I am correct, then the water is simply condensation dripping off the cool parts of the AC components.
Old Jan 26, 2016 | 02:34 PM
Bugeater's Avatar
Agreed it is most likely condensation from HVAC system
Old Jul 31, 2017 | 10:54 AM
WyrTwister's Avatar
If it is clear water , yes , condensate . Normal , no problem . ( he could have the defrost on , in winter . )
If it is colored water, probable coolant , not good .
If it is oil , what color is it , not good ?
God bless
Wyr
scottvo
Aug 2, 2017 09:38 AM
scottvo
Jul 19, 2015 08:44 AM
dtachia
Apr 23, 2011 02:49 AM
Regal LSX
Jul 4, 2009 01:40 AM
gpuvalowski
Mar 18, 2009 09:01 PM
