2014 Lacross engine oil low
Old Jul 19, 2015 | 08:51 AM
scottvo's Avatar
Default 2014 Lacross engine oil low
I changed the oil and filter and now im getting "engine oil low add oil" message. I added 6 qts if 5w30 synthetic. I know the car has oil in it. but this baffles me. any ideas?
Old Aug 2, 2017 | 09:38 AM
WyrTwister's Avatar
Which engine ?
There must be a sensor . This shows the o-ring .
2014 BUICK LACROSSE 3.6L V6 Oil Level Sensor Gasket / O-Ring | RockAuto
Also , check the diagram .
GM OEM-Oil Fluid Level Sensor 12639127 | eBay
I would first try to locate the sensor . Apparently on the oil pan . See if you accidentally disturbed the sensor ot its wiring . When you changed oil .
You might try disconnecting the - battery cable for a few minutes in hopes you can reset the electronics .
Best of luck :-)
Wyr
God bless
scottvo
Jul 19, 2015 08:44 AM
nodsirrah
Sep 22, 2013 10:27 AM
BuickBag
Rainier
Jul 22, 2011 06:19 PM
dtachia
Apr 23, 2011 02:49 AM
Terbronco7
Mar 21, 2011 07:36 PM
