2012 Lacrosse
Old Mar 10, 2024 | 10:31 AM
Scott863's Avatar
Default 2012 Lacrosse
I have 2012 LaCrosse and the radio has power but no sound. I noticed that the turn signals don't have any sound either. The radio will come on for a few seconds then the sound stops. Can someone please help
Old Mar 10, 2024 | 03:53 PM
The only things you can do are check that the connections to the radio are tight and the antenna connection is good. Without some special equip, your best bet is a radio repair shop or maybe a dealership that will most likely do what was suggested and then if that doesn't work either replace the radio or send it out for repair.
Old Mar 10, 2024 | 06:05 PM
Scott863's Avatar
Default Lacrosse
The reverse camera alarm, door chime, and turn signal noise all stop after a few seconds as well. I changed the fuse to the radio and will troubleshoot the rest and see what I come up with
11brick
Oct 11, 2023 06:46 PM
Peter land
Oct 16, 2022 07:31 PM
96ParkAve
Feb 17, 2020 02:49 PM
Irishrev@shownes.com
Mar 20, 2018 04:59 PM
Buickfan
Sep 4, 2011 05:16 AM
