Window switch?
Old May 4, 2008 | 10:03 PM
afphinfan's Avatar
Hi, I posted this in the LeSabre forum but thought it may be applicable here as well ... thanks!
I was trying to help my parents with their 98 LeSabre and an intermittent window switch problem. The passenger window is all the way up and would not come down by either switch. I removed the door panel and pulled thewindow motor; the motor will spin upvia bothswitches but only down intermittently using thedriver's side and not at all with the passenger side. I swapped the wires to the motor and the passenger side up will spin it in the opposite direction. I swapped the relayand that did not change anything. I also tried the rear window switch and that did not change anything, so I'm guessing that it is the driver's side switch. Anyway to test this? Also, do I have to replace the whole switch block for all four windows? Sorry for the long post ... any help is appreciated ... thanks!
Mark
mean60garcia
Nov 22, 2014 07:59 PM
Buick Forum Editor
Aug 7, 2014 12:55 PM
greendurango
Oct 2, 2012 05:20 AM
hawkk72
May 19, 2009 11:54 PM
afphinfan
May 28, 2008 02:22 PM
