vibration At 35mph to45mph
Old May 17, 2007 | 01:05 PM
garllo's Avatar
I have a 2000 Regal LS with 98k mi. It is a great car and I would like to hang on to it . The car has developed one nerve racking trait over the past year. There is a vibration , sort of side to side between 35 and 45mph.After that it smoothens out until 70mph .I do know that it is not tire balancing. It seems to do it in any gear! Any ideas or experience?
Old Jun 6, 2007 | 07:31 PM
Troys 69 GS 400's Avatar
Front end parts are just wearing out. An good alignment shop will help you out.
Old Oct 19, 2008 | 06:28 PM
TrippleT's Avatar
your Tires are probably balding on the inside also...
you need ball joints.. lower im guessing.
and NEW TIRES THAT ARE BALANCED
This is a late entry but could help someone else.
Old Oct 20, 2008 | 08:06 AM
garllo's Avatar
Actually , as it turned out, the vibration was caused by a worn wheel bearing! I probably should have posted that but I had forgotten about the posting on this forum! Thanks again!
Old Oct 22, 2008 | 04:27 AM
TrippleT's Avatar
sweet that helps.
wheel bearings usually make a humming sound.
they dont usually make your car shake...
jerrysbuick
Aug 13, 2006 03:23 AM
Twi_prime
Jul 9, 2006 12:43 PM
eurotraveler
Apr 19, 2006 12:10 AM
