Rochester carb for 455. Slight difference ??
Old Jun 22, 2021 | 04:01 AM
MartinBorch's Avatar
Default Rochester carb for 455. Slight difference ??
Hi
I received my new rebuild carb from RockAuto yesterday. However, there is a slight difference compared to the one I had before. At the bottom right side there is an extra small tube for a small hose. As you can see from the pic (left side is the new one, right side is the old one) I did not have this option before, so now I don't know where to attach the end of the hose coming from the carb. Hope someone can help, thanks
Old Jun 23, 2021 | 06:38 AM
Depending on the year, some engines had a vacuum advance on the dist . that was controlled by a vacuum hose from the port you are questioning.
If your engine doesn't have a vacuum advance on the dist., just put a screw into a small piece of hose and block the port.
shovel1200
Feb 9, 2021 05:39 AM
Busguy71
Jul 16, 2012 01:50 PM
Chevy455BBB
Jun 24, 2012 06:38 PM
BG1
Jun 9, 2011 06:04 PM
1984 buick truck
Apr 5, 2009 11:02 AM
