Removing Harmonic Balancer - 97 Buick LeSabre
Old Apr 16, 2009 | 09:08 PM
OldIron's Avatar
Default Removing Harmonic Balancer - 97 Buick LeSabre
I am trying to remove the Harmonic Balancer from my 97 Buick LaSabre and having difficulty. I would like to verify if the thread is standard or reverse thread. I'm guessing it is reverse. Any suggestions on how to hold the pulley to get the damper bolt loose?
Old Apr 21, 2009 | 10:54 AM
jenbuickv6's Avatar
Default harmonic balancer
the threads are normal.unscrew turning ccw (left) you may need an impact tool to remove it .be carefull not to damage the crank sensor on the right..good luck yvon
Old Apr 21, 2009 | 08:23 PM
OldIron's Avatar
Default Harmonic Balancer
Thanks for the help. We did get the pulley off. It took an impact wrench. Actually we had to take the pulley off because the crank sensor was damaged when the serpentine belt came off. When we got it back together, the check engine light came on and it threw a code P0300. This code means the crank sensor needed to go thru a "crank sensor learn procedure". After the car ran awhile the check engine light went off. It hasn't come back on since and the car is running fine. Do you think this means the "learn procedure" is not needed? Thanks again.
kr95
Apr 18, 2013 09:57 PM
smo
Aug 2, 2011 07:35 PM
bassasasin
Jul 29, 2007 09:06 PM
buckroo
Jun 14, 2006 07:23 PM
