-   -   Power windows don’t work (https://www.buickforum.com/forum/general-tech-help-13/power-windows-dnt-work-174/)
bigdog472000 Sep 21, 2005 04:44 AM
I have a 97 Buick Regal and the power windows don't work. I don't have a clue as to what's wrong. HELP.
MrBSS Sep 21, 2005 02:17 PM
So, no windows work? That probably means that the circuit is dead. Check the fuses and circuit breakers.
Patrick Sep 23, 2005 03:36 PM
i agree..if Every window doesnt work, it almost has to be a fuse issue
Harley Oct 21, 2005 11:52 PM
yeah fuse would be the first thing to change, another thing, and this happend to may car. The switches for the windows, in my car there is a box on the drivers door, houses 4 2 way switches. well I guess it wore out or whatever, I grabbed another one out of a cadilac, cleaned it all up with contact cleaner, tossed it back in and it works good as new, that was over a year ago. But I knew it was the switch pannel cause each window (4 door) would work by it's switch, but none would work off the master drivers door switches.
sdsdsd Dec 1, 2005 10:36 AM
It sounds like a ground problem. You don't have a fuse in the circuit you have a circuit breaker. The circuit breaker goes in like a fuze but it is a silver little box, they do go bad sometimes.
