MA822 shock issue
I replaced my rear shocks with the Monroe 822's as recommended in several of the threads I have read. Very easy job UNTIL pump continues to lift the car up much higher than it should be. The pump does not continue to run after it jacks it up but it remains at that height. It has also killed my battery several times. I'm seriously frustrated....Is there a rear shock I can put on it and pull the fuse to stop the pump from working? The car cant be driven the way it is.Any idea's would be greatly appreciated. My son also tried lowering the sensor level....no help.
carid
Feb 10, 2015 08:55 AM
