HELP 92 SKYLARK 3.3 STALLS
Old Feb 15, 2006 | 02:51 PM
LOPEEE's Avatar
AFTER DRIVING ABOUT 15 MIN. CAR WOULD CUT OFF AND START UP RIGHT AWAY AND DRIVE AWHILE AND CUT OFF.I NOTICED THE BATT. VOLTAGE DROP BEFORE IT CUTS OFF AND THE RPM DROP AT THE SAME TIME.NO CODES STORED IN COMPUTER PARTS CHANGED- CRANKSHAFT SENSOR,MAF,TPS,IAC,INGITTION COIL MODELUE, FUEL INJECTORS, FUEL FILTER,.
Old Feb 16, 2006 | 03:01 PM
Erakiel81's Avatar
Have you tried tu unplug your EGR valve ? I see you check all "standard" thing except for this one.
Old Feb 16, 2006 | 03:57 PM
LOPEEE's Avatar
THANKS FORHELPING BUT I FOUND OUT THE 3.3 DOES NOT HAVE A EGR VALVE. I AM GOING TO TRY A FEW OTHER THINGS BEFORE I CHANGE THE ECU.
brightfame03
Nov 12, 2007 08:39 PM
focusownerskid
Oct 17, 2007 04:08 PM
techmike
Jun 15, 2007 11:03 AM
MNM3461
Apr 3, 2007 05:35 PM
topn01
May 10, 2005 03:15 AM
