Heater hose diameter
Old Nov 27, 2023 | 02:26 PM
fsj's Avatar
fsj
Default Heater hose diameter
Hello all! The heat in my 2008 Lacrosse CXL 3.8 has gone luke warm. I'd like to back flush the core with a flushing tee connector. What size hose is the outlet side? This should work? Hopefully?
Old Dec 6, 2023 | 02:45 PM
Before getting involved in what may or may not be the problem, Do we know if the thermostat might be stuck open.
A quick way to tell, cold engine ,remove the radiator cap ,have someone start the engine and look into the radiator. If you see the coolant circulating with a cold engine, the thermostat is stuck open. If replacement is required, a 195 degree thermostat should be installed..
rdanth
Nov 28, 2023 05:36 PM
Bentwings
Nov 30, 2018 02:46 PM
blu3g
May 15, 2008 11:16 AM
rdanth
Jan 8, 2008 12:28 PM
rdanth
Jan 8, 2008 12:22 PM
