Erratic Tachometer
Old May 13, 2008 | 04:30 PM
PatVanHalen5150's Avatar
On my new-to-me 1998 LeSabre Limited.
Tachometer goes bezerk as soon as i start it up. All over the chart.
Any suggestions?
Old May 13, 2008 | 05:41 PM
samueljackson's Avatar
the tach signal is fed through the ICM, you could try to clean the harness that goes into the icm. if that looks clean, you can check the resistance between the icm and the pcm. should be at or close to 0 ohms.
but you would need a fsm to find the pinouts on the icm side. im pretty certain the white wire on the icm harness is the tach feed.
BPA1986
May 21, 2008 07:51 PM
Blu 67
May 18, 2008 01:25 PM
amandus
Jul 18, 2007 12:12 PM
granny_rocket
Dec 30, 2005 01:03 AM
Doug Rustin
Oct 28, 2005 02:25 PM
