ECM OBD I Codes
Old Nov 5, 2005 | 11:06 PM
firefighter0029's Avatar
Can we Start a Sticky train on here for ECM OBD I Codes?
I have the codesfrom my GM Service Manual But I'm Missing some and need the Codes from a 3800 Series I Supercharged engine Specificaly the Code 56.
Codes for 3800 Series I (Vin Code L)
Code 13 Oxygen (O2) Sensor Circuit (Open Circuit)
Code 14 Coolant Temperature Sensor (CTS) Circuit (High Temp. Indicated)
Code 15 Coolant Temperature Sensor (CTS) Circuit (Low Temp. Indicated)
Code 16 Battery Voltage Too High or Low
Code17 Spark Referance Circuit
Code 21 Throttle Position Sensor (TPS) Circuit (Signal Voltage High)
Code 22 Throttle Position Sensor (TPS) Circuit (Signal Voltage Low)
Code 23 Intake Air Temerature (IAT) Sensor Circuit (Low Temp. Indicated)
Code 24 Vehicle Speed Sensor (VSS) Circuit
Code 25 Intake Air Temperature (IAT) Sensor Circuit (High Temp. Indicated)
Code 26 Quad-Driver (QDM) Fault
Code 27 Gear Switch Diagnosis (2nd Gear)
Code 28 Gear Switch Diagnosis (3rd Gear)
Code 29 Gear Switch Diagnosis (4th Gear)
Code 31 Park/Neutral (P/N) Switch Circuit
Code 34 Mass Air Flow (MAF) Sensor Circuit (GM/SEC Low)
Code 38 Brake Input Circuit
Code 39 Torque Converter Clutch (TCC) Problem
Code 41 Cam Sensor Circuit
Code 42 Electronic Spark Timing (EST) Circuit (Crank Sensor)
Code 43 Electronic Spark Timing (EST) Circuit (Knock Sensor)
Code 44 Oxygen (O2) Sensor Circuit (Lean Exhaust Indicated)
Code 45 Oxygen (O2) Sensor Circuit (Rich Exhaust Indicated)
Code 51 MEM-CAL Error (Faulty or Incorrect MEM-CAL)
Code 66 Low A/C Refrigerant Charge
Code 69 A/C Head Pressure Switch Circuit
3.1(Vin Code T)Have most of the same codes except.....
Code 32 Exhaust Gas Recirculation (EGR) Circuit (Electrical Diagnosis)
Code 33 Manifold Absolute Pressure (MAP) Sensor Circuit (Signal Voltage High-Low Vacuum)
Code 34 Manifold Absolute Pressure (MAP) Sensor Circuit (Signal Voltage Low-High Vacuum)
Code 35 Idle Air Control (IAC) Circuit
Code 41Cylinder Head Error (Faulty or Incorrect MEM-CAL)
Code 53 System Over Voltage
Code 54 Fuel Pump Circuit (Low Voltage)
Code 61 Degrated Oxygen (O2) Sensor
Code 66 A/C Pressure Sensor Circuit
Edited by: firefighter0029
Old Nov 8, 2005 | 01:10 PM
Patrick's Avatar
Administrator
i have stickied this..great info..thanks!
Old Oct 28, 2007 | 01:56 PM
samueljackson's Avatar
code 56 for the 92s was a known ecu flaw. it is to be ignored. its a vats code.
wnlewis
Jun 15, 2013 10:00 PM
samueljackson
Jan 19, 2008 12:09 PM
tmcnally6
Nov 6, 2007 03:53 PM
Semicond
Sep 6, 2006 11:56 AM
wingnut
Aug 9, 2006 02:24 PM
