-   -   coolant leak (https://www.buickforum.com/forum/general-tech-help-13/coolant-leak-662/)
dennysm Dec 6, 2006 02:45 PM
&lt; =&gt; <!--
var SymRealOnLoad;
var SymReal;
Sym()
window.open = SymWinOpen;
if(SymReal != null)
SymReal();
SymOnLoad()
if(SymRealOnLoad != null)
SymRealOnLoad();
window.open = SymRealWinOpen;
SymReal = window.;
window. = Sym;
window.onload = SymOnLoad;
//--></>I have a 97 Buick LeSabre with 178k miles. I am using coolant and the dealer tells me that the plenum is leaking and not the water pump. I have looked at the water pump and see no visible signs of coolant residue but I can smell the coolant. Any advice, is this true?
var SymRealOnLoad;
var SymReal;
Sym()
if(SymReal != null)
SymReal();
SymOnLoad()
SymRealOnLoad();
SymReal = window.;
window. = Sym;
Edited by: dennysm
MrBSS Dec 6, 2006 06:50 PM
Suggest you check the heater hoses. There is a plastic elbow on one that feeds into the block. The o-rings or the elbow itself often leak intermitantly.
