97 Regal
Old Oct 13, 2008 | 07:49 AM
Larry Graff's Avatar
Wjfes 97 Regal 30000 miles as of yesterday. While driving if you use turn signel the car will stall !!!!!!! all dash lights come on and gauges go nuts. I am able to restart if you play around with blinker switch or even 4 ways once running if I use turn signel it will stall car again. Was able to get car home about 15 mile drive by not using turns sig. once in drive turnrd sig, and it killed motor !!!!! any ideas ??
Old Oct 20, 2008 | 04:39 AM
Rusty's Avatar
sounds like a ground problem, that would be the only thing I can think of.
Old Oct 22, 2008 | 04:29 AM
TrippleT's Avatar
sounds like the wireing inside of your searing column is screwed up...
maby open wires. and when you press down on teh blinker it touches some wires together.
[img]smileys/smiley10.gif[/img]
