-   -   94 le sarbre no start... HELP (https://www.buickforum.com/forum/general-tech-help-13/94-le-sarbre-no-start-help-1641/)
nissantech25 Jul 16, 2008 09:30 PM
i have 3.8l 94 lesabre that wont start. new ignition module and battery put in. ignition module started to spark and would not crank. i started to tap the coil packs and the check engine light came on and started to crank. i have fuel but no spark.. lead me in the right direction?
thanks ryan
samueljackson Jul 20, 2008 03:34 PM
1 Attachment(s)
I would start to suspect the crank position sensor. but before just buying a new one, I would check the resistance in the wires from the sensor to the ICM. and also from the ICM to the PCM. heres a schematic that tells you the pin-outs.
Attachment 785
and heres a thread that may help you as well
http://www.pontiacbonnevilleclub.com...wtopic.php?f=1 9&t=2371&start=0
nissantech25 Aug 9, 2008 12:41 PM
i have a new problem. i put wires and plugs in and it started.
now i have absolutely no power in the dash lights, centre console, interior lights and it wont even crank over.
i was trying to find the voltage that the alternator was putting out and as soon as i touched the probes from the multimetre to the battery post everything cut out and now i have nothing.
i checked all the fuses under the hood and under the drivers side dash and they all have power. when i checked the fuses under the passenger side dash i found i had no power to misc engine control, ecm, fuel pump, and ignition. i changed the fuses and now have power flow but still have no lights.
any ideas?
bookie0116 Aug 19, 2008 02:23 PM
Wow
