| steveinnepa |
Aug 20, 2012 10:02 AM |
1998 Park Ave Dash turn signal indicator on dim
Recently, the right turn signal indicator on the dash, came on. The indicator is dim and on constantly, whenever the parking / headlights are on. The exterior right front marker light is also dimly lit, when the parking / headlights are on. The same marker light bulb flashes brightly / normally, when the right turn signal is on. The marker light bulb has two wires, a blue and a brown. Here's what I have checked, so far. All bulbs are good. I replaced the turn signal flasher. With the parking lights on and the marker light dim, I checked for voltage at the two socket pins ( blue & brown wires) Both wires have voltage. Neither is a ground. I checked the left marker light, which works fine and with the parking lights on, the brown wire is ground and blue has battery voltage.
Since, the small push in marker lights serve two purposes, 1. On with parking / headlights. 2. Flash along with the front corner lights. I am thinking that my problem, of a dimly lit exterior marker and dash turn indicator are related to a ground problem. But, where? Or possibly a bad turn signal multifunction switch? I could use some help on this one.
Steve
