1972 Skylark. External Regulator, Alternator, Battery Wiring Help
Old Jun 4, 2011 | 03:45 PM
Brandon's Avatar
Default 1972 Skylark. External Regulator, Alternator, Battery Wiring Help
Hi Everyone,
My 1972 Skylark sustained an electrical fire a while back and torched the main portion of the wire harness that goes across the engine.
I've managed to peace back together most of the wires, but not I'm a bit stuck/confused and could use your help.
According to this diagram:
One of the RED wires going from the starter solenoid to the junction box should intersect with both the Regulator's #3 wire and the Alternators Battery wire. (NOTE: There's no remaining evidence on how these wires were ever spliced/joined together. All the wires in question, aside from the solenoid wires, do not appear to have a matching counterpart)
However when connecting these wires together, the battery gets too much current and starts to spew water/acid. Checking the voltage on the battery at idle shows 17.5-16.5 fluctuations. Shouldn't this be 13.8?
The regulator and the alternator are new parts. Also, I have a mystery wire and I'm not sure what it goes to or if it is related to the issue I'm experiencing.
I know the first suggestion I'm going to get is "convert" to an internally regulated alternator, but I'd like to stick with what I've got if possible. Any suggestions, ideas, tips, anything at all would be greatly appreciated!
Some more images that may be useful.
guty7707
Dec 6, 2018 08:59 AM
Crowsville
Audio/Visual Electronics
Jul 12, 2012 06:03 PM
tntctrm
Nov 30, 2011 08:52 PM
bwiseman
Jul 16, 2007 08:20 PM
Jerry
Aug 2, 2005 12:46 AM
