Ignition module, coil, everything all messed up
Old 11-14-2016, 11:46 AM
Jfinnkma91's Avatar
Default Ignition module, coil, everything all messed up
2 weeks ago my car broke down, I replaced a cracked ignition coil and the ignition control module. No luck. Still no start. Took it to a shop, 641 dollars later they replaced the crank sensor for me. Starts and ran okay for 3 days, now I'm having bad misfire in cylinder 3 and 6. No spark whatsoever. I replaced the already new coil again, still no luck, put another ignition module on, still no luck. Any ideas before I burn this car
Old 07-17-2017, 06:13 AM
There's also the camshaft position sensor, maybe the problem to start with? Car may of been torched by now, hmm.
VanBuren
01-20-2015 06:43 PM
iamrabroad
11-30-2008 06:54 AM
Quick Reply: Ignition module, coil, everything all messed up
