-   -   Ignition module, coil, everything all messed up (https://www.buickforum.com/forum/engine-internal-16/ignition-module-coil-everything-all-messed-up-7679/)
Jfinnkma91 Nov 14, 2016 11:46 AM
2 weeks ago my car broke down, I replaced a cracked ignition coil and the ignition control module. No luck. Still no start. Took it to a shop, 641 dollars later they replaced the crank sensor for me. Starts and ran okay for 3 days, now I'm having bad misfire in cylinder 3 and 6. No spark whatsoever. I replaced the already new coil again, still no luck, put another ignition module on, still no luck. Any ideas before I burn this car
Rich B. Jul 17, 2017 06:13 AM
There's also the camshaft position sensor, maybe the problem to start with? Car may of been torched by now, hmm.
