wont start first time
Old May 25, 2006 | 12:48 AM
xfrankiex's Avatar
i have a 97 ultra 3.8 supercharged when i go to start it the first time it just turns over and over. as soon as i turn the key back and the try to restart the car it starts right up every time. does any one have any ideas it would be appreciated
Old Jun 9, 2006 | 06:23 PM
SSEBonne90's Avatar
check you fuel pressure and regulator.
Old Jun 26, 2006 | 05:28 PM
bassasasin's Avatar
It may have trouble reading the key.. check for spark missing. Many things possible. If the spark is missing the computer may not be allowing to start. Then its check key security system. I believe it reads the key through Osmosis.. sortof. Chip in key. Like a microchip in a pet.
Edited by: bassasasin
Old Jul 9, 2006 | 06:29 PM
samueljackson's Avatar
i agree w first reply, first check for proper fuel pressure. start with simple and change filter.
Old Sep 14, 2006 | 01:35 AM
bassasasin's Avatar
Im betting on the key.. too. Good place to start. You look for codes at a parts place. A shop will charge you.
I wonder if the security light lights up on that model for a VATS error.
The key has a resistor read by the VATS system. Theres about 15 different resistor values you might have. The VATS system puts a signal to the PCM to allow a start. Sometimes Ive heard in forums engines will start and quit in 10 seconds, and others die on the road for this problem.
http://www.thirdgen.org/vats_passkey_system
Good luck.
Old Sep 22, 2006 | 05:23 PM
Sweeper11's Avatar
On some cars you prime the system by sturning the key to the on position then wait a second then try starting the motor, I do not know if you have this with your case though.
Buick Forum Editor
Feb 20, 2014 10:47 AM
Buick Forum Editor
Feb 12, 2014 01:43 PM
mcafferty
Nov 8, 2006 08:35 PM
xfrankiex
May 26, 2006 01:10 AM
