Hi. I just came home after some driving. When I drove the car, the horns started honking. Usually, the horns doesn't work, but now they honked all the time, like if it was an anti-theft larm. I disconnected the horns, and the honking stopped. But I heard a relay clicking all the time, and the headlights were blinking. If the car is equipped with an anti-theft system (which I doubt), it makes sense, that the lights are blinking too. Now, I need helpwith this problem. I really don't like driving it if I know there is something wrong, and just because I can't hear it, theanti-theft isstillsending signals that the car is being stolen or something. What can I do to deactivate the system? I read about some codes in the repair manual, but I have no code. I didn't even know it had an anti-theft system. Fast answers are appreciated. Thanks / Andersson |
you will not get codes from an aftermarket alarm. first thing you have to do is find the alarm module. they are usuall a black plastic box. about 3-5 inches. usually they will be installed next to the fuse panel. look in that area and try to find something foreign. maybe take a pic of what you find, before you remove it
The alarm should deactivate when the key is locking/unlocking the car. I don't know what happened, but now it's working fine. The horns works well too. Don't ask me why they didn't work before, or what I did, but they are working now, and that's what it's all about, right? [img]smileys/smiley2.gif[/img] |
an aftermarket alarm will not deactivate just because the the key is used. the alarm doen not know the difference between a key or a screwdriver. but the important thing is it works. glad to hear. but sould the problem return (knock on wood it doesn't) id still suggest what i wrote in my original response. |
| All times are GMT -5. The time now is 03:00 AM. |
