Front disc brakes overheat
Old May 11, 2020 | 11:29 AM
moundtown's Avatar
Default Front disc brakes overheat
1995 Park Avenue. The diver's side front disc brakes started overheating to the point that they were smoking. Upon inspection, I found that the inside brake pad had worn down much more than the outside pad. I removed the caliper from the wheel to replace the pads and found it nearly impossible to compress the piston even with the bleeder loosened. I figured the caliper was shot, so I bought and installed a new one. Now a few days later the brakes are overheating again. Can someone suggest what might be causing this?
Thank You
Old May 11, 2020 | 12:51 PM
I would be very suspicious of the brake hose for that caliper.
If you try to depress the caliper piston and have the same problem , try loosening the brake line at the connection where the hose connects to the metal line by the chassis.
If you can depress the caliper piston now , the hose is the problem and needs to be replaced.
Let us know what you find, thanks.
Old May 11, 2020 | 02:29 PM
moundtown's Avatar
Thanks for the response. A couple of people in another forum told me almost exactly the same thing. Looks like I'm off to get the brake hose.
Old May 12, 2020 | 11:52 AM
This could all be good, but we like to prove our suspicions before going out and buying things. There could be other possibilities, but the worst thing you would have had to do is remove the wheel to get to the connection and spread the caliper. Let's hope that is all it was.
cbcorde1
Sep 19, 2024 09:20 PM
andyb
Aug 28, 2008 07:48 PM
BenSpencer23
Aug 22, 2007 12:43 PM
MrChips
May 31, 2007 05:18 PM
111jag
May 22, 2007 08:23 PM
