-   -   blower motor problem (https://www.buickforum.com/forum/electra-park-avenue-25/blower-motor-problem-82/)
svofrk Apr 10, 2005 04:22 AM
I have a '90 Park Avenue with the "electronic climate control" option. The other day I had the AC running and the blower fan stopped working. I suspected a blown fuse, checked fuses-all O.K. Took blower motor out-tested O.K. I have replaced relay above blower cabinet, tried a new resistor module in blower cabinet, jumpered fuse link, tried my backup indash control keypad, still cannot get blower working. I am fit to be tied. Any help out there?
Erakiel81 Apr 12, 2005 01:54 PM
Have you probed if any voltage present at the blower motor ?
If you have it may be the motor has a bad ground. Also check if all
contact are'nt oxidized. You may have voltage but almost no ampere if
you have bad contact. Hope it can help
MrBSS Aug 11, 2005 11:49 AM
I think it will stop working if the A/C charge gets low. I have a '92 Ultra (which I'm selling) that did that. As I remember, the read-out flashed also.
xfrankiex May 25, 2006 12:52 AM
check voltage at the blower motor plug.
samueljackson Jul 9, 2006 06:33 PM
jump the relay if no voltage going to motor.
