Transmission Shift Linkage
Old Dec 13, 2015 | 08:12 AM
morganbryane's Avatar
Default Transmission Shift Linkage
I had to replace a rusted RF brake line and the RF tie rod end. The car sat so long after I put it back together, I forgot to attach the LF tie rod end. I have now since attached the LF tie rod end.
Now the shift linkage seems to be out of adjustment. I cannot start it unless I put it in neutral. The PRNDL indicator doesn't indicate or light up in Park and the wheels turn for what I think is in the Park gear.
Did I screw something up the way the transmission shifts? I don't see any loose electrical connections. Is this something that can be adjust at the transmission shift linkage?
northwing67
Jul 25, 2014 02:53 PM
northwing67
Jul 18, 2014 05:53 AM
sfindley23
Enclave
May 5, 2014 06:42 AM
markdexter
Aug 5, 2010 10:30 AM
MikeS67
Apr 18, 2009 11:55 AM
