Transmission not engaging properly
Old Feb 1, 2012 | 11:34 AM
D_Brindley's Avatar
Default Transmission not engaging properly
Hey everyone,
New to the forums and I would love some help understanding my problem.
I drive a 98 Century with 200K miles. As the Dallas winter started to hit, I noticed that on cold mornings, when I started the car and shifted into overdrive, the transmission would not engage for about 30-60 seconds. After the car had been driven once that day, it would be fine until it sat out through another cold night and I would get the same problem the next morning.
Now the problem has progressed to every time I start the car, the transmission does not engage for quite a while.
I have found that if I shift it to 1st, it will shift into gear in about 1-2 seconds with a small, but noticable, 'thunk'. After that, I can shift into overdrive and everything's good-to-go.
Can anyone shed some light on why this might be happening?
Thanks,
DB
Old Feb 1, 2012 | 07:12 PM
Have you checked the transmission fluid? Has it or the trans filter ever been changed?
Old Feb 1, 2012 | 07:13 PM
Merc6's Avatar
Welcome. What he said since he hit submit first. Are you using a normal trans fluid change schedule or the 100,000 mile one the 1998 century brochure told you to use?
thatyoungin
Feb 26, 2013 05:05 PM
Gucci Mane
May 4, 2009 08:46 PM
MikeS67
Apr 18, 2009 01:41 PM
MikeS67
Apr 18, 2009 11:55 AM
summerfun
Oct 21, 2008 09:55 AM
