turn signal/hazard electrical circuit
Old 10-15-2011, 10:53 PM
qman's Avatar
Angry turn signal/hazard electrical circuit
I have a 03 century. I replaced the relay, flasher, and bulbs and checked fuses. what i find is interesting is there are no fuses marked turn signals which is common. please advise.
Old 10-16-2011, 05:29 AM
Do you have the owner's manual?
It should answer that question in the "fuses" section.
Old 10-16-2011, 05:51 PM
turn signal/hazard electrical circuit-centfuse.jpg
(click on the thumbnail to make bigger)
This is the diagram of the fuse panel on the passenger side. The fuse for the turn signals/park lamps is in the last row, 4th column from the left.
Old 11-03-2011, 02:55 PM
eye144's Avatar
Default obd 1 diagram for 94 lesabre
is there a diagram for OBD 1 94 Lesabre where to place paperclip to produce error code. I had a tech find out 1 time. It was the upper RH port with another plug, but I cant remember which hole the other part of the paper clip goes to. Thanks if you have ideas.
Old 11-03-2011, 03:56 PM
Ruroni
05-09-2008 07:51 PM
aivideo
05-04-2008 07:11 PM
da_kuniva_2
10-18-2007 09:59 AM
Turbo_Boss
01-30-2007 09:09 PM
sixty7rs
12-07-2005 03:16 PM
Quick Reply: turn signal/hazard electrical circuit
