< => <!-- var SymRealOnLoad; var SymReal; Sym() { window.open = SymWinOpen; if(SymReal != null) SymReal(); } SymOnLoad() { if(SymRealOnLoad != null) SymRealOnLoad(); window.open = SymRealWinOpen; SymReal = window.; window. = Sym; } SymRealOnLoad = window.onload; window.onload = SymOnLoad; //--> </> HI All Need Help ... I am trying to get ABS codes. My wheel sensors and cables check out good with a meter. The ABS drops out and traction light come on when I am near the end of a stopping action then goes off when I ease up on the brake. No leaks, caliper seals dry, brake cylinder seals dry, ABS disconnected have normal stopping behavior and no peddle fade. This 94 Century is a fluke, I have been looking at scanners upto the $300 to $400 range without luck. Gm obd1 with 12 pin dlc jump pins A& B to get codes. I have A, K, and M to work with. Schematic with dlc lines would help, any and all info would be great. A scanner name and number? My full appreciation to you if you have the savy I'm looking for. grayelve |
| All times are GMT -5. The time now is 11:41 PM. |
