BF Help & Suggestion Center Need help with BF? Ask... Have a suggestion to better BF? Tell us here...
1990 LeSabre Limited engine stalls
Old Jul 26, 2010 | 01:18 PM
cwo1's Avatar
Default 1990 LeSabre Limited engine stalls
After warmup engine stalls during normal driving (1500-2500 RPM). Putting transmission is neutral engine restarts immediately and revvs fine (no problem 3000-4500 RPM). Engine pulls fine when accelerator pedal floored. No check engine light and mechanic says he can't find any codes or get it to stall. New gas, FI cleaner added, new air filter, new fuel filter, new plugs, new ignition wires, new crankshaft sensor. 104K easy miles. Thx.
Old Jul 1, 2015 | 08:35 AM
jbh00buick's Avatar
I had the same problem on my 2000 buick LaSabre. I put a new idle control sensor on it and cleaned the fuel injectors. Problem solved.
onlyHesaves
Mar 15, 2010 01:53 PM
Cosmic
Dec 19, 2008 08:47 PM
techmike
Jun 15, 2007 11:03 AM
MNM3461
Apr 3, 2007 05:35 PM
topn01
May 10, 2005 03:15 AM
