DIY Article: Replacing the Oxygen Sensors on a '02 Rendezvous
Old Aug 16, 2011 | 11:07 AM
BuickBag's Avatar
Default DIY Article: Replacing the Oxygen Sensors on a '02 Rendezvous
Hello again Buick fans!
I'd like to share a write-up on replacing the oxygen sensors in a Rendezvous with you guys. There are two o2 sensors: The Heated Oxygen (HO2S) Sensor (1) is located in the exhaust manifold. The Heated Oxygen (HO2S) Sensor (2) is located in the exhaust pipe, after the converter. Refer to this'02 Rendezvous Exhaust components listing for a complete parts list, diagram and more.
Replacing the HO2S Sensor 1-
1) Disconnect the electrical connector.
2) Raise the vehicle.
3) Remove the heated oxygen sensor.
Note: If the engine temperature is not above 120°F (48°C), the oxygen sensor will be difficult to remove.
4) Install the heated oxygen sensor.
5) Tighten the HO2S 1 to 30 ft. lbs. (41Nm)
6) Reconnect the electrical connector.
HO2S Sensor 2-
2) Remove the heated oxygen sensor.
3) Install the heated oxygen sensor.
4) Tighten the HO2S 2 to 30 ft. lbs. (41Nm)
5) Reconnect the electrical connector.
6) Lower the vehicle.
7) You're done!
BuickBag
Dec 19, 2019 09:41 PM
tvsdprasad
May 21, 2015 05:51 AM
BuickBag
Mar 3, 2013 12:16 PM
BuickBag
Oct 11, 2011 01:09 PM
BuickBag
Jul 29, 2011 11:15 AM
