95 Buick Sabre will not chagrge
Old 03-18-2014, 02:14 AM
tim2's Avatar
Default 95 Buick Sabre will not chagrge
My niece has had three batteries, and two alternators replaced and it still won't charge. I am trying to find out if the wire coming from the alternator has a fusible link? If not can I run a new wire from the alternator to the battery? If so what wire gauge and types of ends are required? I am hoping to make the two hour drive today or tomorrow to try and recover and repair it. Thank you for any possible help.
Old 03-18-2014, 03:21 AM
There were three different types of alternators used in 1995 on Buicks. If the plug on the alt has three wires , it gets it's charging signal from the PCM(computer).
If all the grounds are checked and all connections are good , it could be a computer problem. If the wrong alt was installed that could also complicate things. Just replacing a wire may not correct the problem.
Old 03-18-2014, 06:02 AM
tim2's Avatar
Well I am not sure if it has three wires or not I have never seen the car. I was hoping that maybe I could replace just the wire that sends current to the battery. I hope someone else chimes in so I don't have to make the drive just to look and figure out what harness it is. It is the correct alternator I know that for sure, jut unsure of the wiring harness.
Lammersd
03-21-2010 02:25 PM
cellblock_g
09-27-2009 08:53 AM
birdman1
09-20-2007 07:34 PM
Foler2521
10-18-2006 08:19 PM
browneyekid
12-29-2005 12:30 PM
Quick Reply: 95 Buick Sabre will not chagrge
